2025 LX 700h Overtrail dealer says raised suspension caused gross alignment provlems
John S1
I’m looking to see whether other 2025 Lexus LX 700h Overtrail owners have experienced serious alignment problems after using the adjustable suspension in the raised position. My vehicle has approximately 18,500 miles on it and the tires are shot. Pep Boys found the alignment significantly out of specification, and the Lexus dealer in Naples, Florida, also confirmed that it was grossly out of alignment. The dealer attributed the problem to driving with the suspension raised. The plan is to put the leveling system in normal mode, align all four wheels, replace the tires, and then evaluate the results. Few questions for other owners: 1. Have you experienced significant alignment problems with your LX 700h Overtrail? 2. Has your dealer told you that using the raised suspension caused alignment issues? 3. Have you found any Lexus technical guidance or service bulletins addressing this issue? 4. After an alignment, did your alignment remain correct when raising and lowering the suspension? I’m not suggesting that there’s a defect, just trying to hear from other owners and see whether there is a pattern. Thank you for sharing your experiences.
I have a 26 with 13K miles on it and I feel like my tires are wearing a little premature, but in an even pattern - not like what you would typically expect from a misaligned rig. I’m driving around in H1 most of the time.
Did you have uneven wear on the tires (more towards the edge)? Would love to hear from others as well.
What you experienced is NORMAL. First...on Normal height, go look at your front tires. They will look aligned and flat to the ground. How go up to Hi2 and then look at your tires. They will be "crooked" and out of alignment. This is normal. When driving on trails in Hi2, little extra wear will occur as trail runs don't go 100-miles. That's what Hi2 is for. Then Hi1...you can run in Hi1 up to ummm, I forget, 60MPH(?). But IF you run in Hi1 all the time because you run around town you need to have the vehicle aligned in the Hi1 mode. But then you're hosed if you go on high speed trips an it lowers to Normal. Then you're out of alignment again. So the system works perfectly if you run in Normal. Hi1 for short distances if you like the look. But Hi1 is also mainly for running trails when you need a bit more ground clearance. Hi2 for even tougher off-road obstacles.
  • #4
Your knowledge is greatly appreciated! Sure wish a sales person or new car review guide had covered this.
I spent $120K plus for the Hi ride look!
  • #5
All tires wore on outer side.
Me too! Slee Off-Road has made a box that would override the AHC height for previous Cruisers. But he told me on the 600/700h there are many things that control height so it might not be possible for us.
